Already another season! I’ll post info about season 11 Playoffs here, including seeds and replays for every seed played. If anything here is incorrect or missing (like if replay downloads break) please let me know so I can fix it! Reply in this thread, dm me on discord, or email me at contact.r0hkx at gmail.
Ranked separates world seeds into four component seeds (Overworld, Nether, End, and RNG), but End and RNG seeds are always the same as the Overworld seed in Playoffs, so only OW and Nether are provided here.
MSS Replays
https://www.mediafire.com/file/zb9mur8eqyqno50/s11-mss-replays.rrf/file
seed 4 is missing because the ref’s pc crashed :(
MSS Seeds
| Seed | Overworld Type | Overworld Seed | Nether Seed | Match ID |
| 1 | Ruined Portal | 90134400203531708 | 36087797591028 | 11659080 |
| 2 | Buried Treasure | 536137082322896724 | 207683296411788 | 11659367 |
| 3 | Shipwreck | 8043607561116179272 | 269424189664320 | 11659671 |
| 4 | Village | 1247773318301500162 | 206125174370898 | 11660219 |
| 5 | Desert Temple | 973053774260777612 | 218655667146774 | 11660495 |
| 6 | Village | -936544665379804109 | 234358900435249 | 11660890 |
| 7 | Shipwreck | 3674956997033489040 | 66853339086077 | 11661227 |
| 8 | Ruined Portal | 49816501474010731 | 208311256009996 | 11661650 |
| 9 | Desert Temple | 3873261618678163266 | 210828595681571 | 11661912 |
| 10 | Ruined Portal | 3621113443766699237 | 24019883185035 | 11662158 |
LCQ Info
The info here is most of what was sent to the players in the days leading up to LCQ.
Schedule and Timings
- Seed 1 of S11 LCQ is scheduled (and expected) to start at exactly 2026-09-05T16:00:00Z. Players should show up and join the private room at least 10 minutes early.
- The seed time limit is 15 minutes, and there will be 3 minutes before the next seed starts.
- We will operating a rolling schedule, which means if all players finish before the 15 minute time limit ends, then we move the timings in line with that.
- This means that the gap between seeds will remain 3 minutes, except for when private rooms change, in which case the gap between seeds will be 5 minutes.
- New private rooms are created after Seeds 3, 5 and 7.
- After seed 1, you are expected to be in the private room at the latest 2 minutes before the seed begins - it is your responsibility to ensure you are on time.
- You will have a referee informing you of the start time of each seed and the time until the next seed starts in #lcq-info The start time of the next seed will be shared once the previous seed ends. In addition, this channel is where the private room information and overworld type information will be sent.
- There will be one break after seed 5, there will be 15 minutes before seed 6 starts - you will need to be in the private room 2 minutes before at the very latest.
Seeds:
- LCQ will use seeds from the pre-S12 filter.
- Seeds will not be manually reviewed for quality.
- LCQ will use freshly filtered seeds that haven’t been in past Ranked seed pools.
Private room settings:
- Max Players in This Room: 100
- Match ends with completions: 24
- Optimized Live Replay: ON
- Force Rejoin with Reconnection: ON
- Optimize Live Replay
- Reduce Waiting Time: OFF
- Show Advancement Only Once: ON
- Custom Room Name: “S11 LCQ”
- Time Limit: 15:00
- Seeds will be manually entered
- Display seed type will be set
- Join request mode is enabled
- All other settings are default
Procedure:
- 30 minutes before seed 1 starts, we’ll send a reminder message and start the Last Chance Qualifier stage.
- Players must be undeafened in the audience of the stage for the entire duration of the event or until they’re eliminated.
- Join the stage no later than 15 minutes before Seed 1 starts.
- 15 minutes before Seed 1 starts, we’ll send the room code and overworld type in #lcq-info.
- Please join the room as early as you can, just to make sure you’re able to join it without issue. Once you know you can join, you can leave to warm up for a few minutes.
- 5 minutes before Seed 1 starts, we’ll give a heads up.
- 1 minute before each seed starts, we’ll give a heads up.
- Shortly after each seed ends, we’ll send a message in #lcq-info with the next room code, overworld type, and a timestamp for when the next seed will start.
Additional important info is on the Ranked wiki, specifically these two pages:
https://wiki.mcsrranked.com/playoffs/rules#qualifiers-showdown-rules
https://wiki.mcsrranked.com/playoffs/last_chance_qualifiers
optimized live replay was enabled for all 10 seeds, so replays will only contain player info (basically perma ghost mode, so no entities, placed or broken blocks, etc). this was done to reduce server load and lower the risk of a server crash or really bad lag. it could have been enabled for the last 3 seeds at least without any risk though i just forgot i’m sorry
LCQ Seeds+Replays
| Replay | Overworld Type | Overworld Seed | Nether Seed | Match ID |
| 1 | Village | 801693453823844964 | 100944589639190 | 13099345 |
| 2 | Buried Treasure | -211450129302687039 | 246906096015124 | 13099614 |
| 3 | Ruined Portal | 373857333152186079 | 230186322523107 | 13099886 |
| 4 | Desert Temple | 7395189254077506835 | 202211287765541 | 13100211 |
| 5 | Village | 3166115918462769770 | 229074513236058 | 13100492 |
| 6 | Shipwreck | 7534636090060946800 | 53987429108589 | 13101174 |
| 7 | Desert Temple | -2184072867056799981 | 4976105435949 | 13101541 |
| 8 | Shipwreck | 3418456737584198671 | 169809153061683 | 13102015 |
| 9 | Buried Treasure | -6786847073025367411 | 102269527716778 | 13102410 |
| 10 | Desert Temple | -1539962878324595069 | 247985278157119 | 13102847 |
Bracket Info
Private Room Settings:
- Max Players in This Room: 2 (later changed to 10)
- Use Player Ready System: ON
- Instead of a Start button, you have a ready button that you can click to indicate to the ref that you’re ready. The text will be green for you when you’re indicating you’re ready.
- Disable Forfeit: ON
- Custom Room Name: “S11 PLAYOFFS”
- Seeds will be manually entered, freshly filtered, unchecked, pre-S12 filter seeds
- The overworld type will be displayed on the countdown screen, just like normal ranked (and like in LCQ)
Misc
The ‘Disable forfeit’ private room setting was accidentally left disabled first few matches of the first day. This was brought to Playoffs staff’s attention but we didn’t think it was urgent, and planned to just disable it in the preset for the next day. After edcr forfeited in the second seed of his match against Joomz, we changed our mind, and enabled the setting for the rest of the seeds that day.
edcr was disqualified for conduct after the first weekend of bracket had concluded, so Feinberg received a bye in his quarterfinals match that would have been against edcr, and one less match was played in bracket than normal.
JoomzMonkey or Joomz is the name of the 16 seed bracket participant, but his Minecraft username at the time of Playoffs was “lauveer”, and his skin was changed as well. lauveer is an active member of MCSR and her Minecraft username at the time of Playoffs was “JoomzMonkey”. Based on the name history of the two Minecraft accounts (and other things) they appear to have changed their account usernames to effectively swap names (not account sharing). This confused a lot of people during Playoffs, to say the least.
Bracket Seeds+Replays
| Replay | Player 1 | Player 2 | Overworld Type | Overworld Seed | Nether Seed | Match ID |
| RO16-1-1 | doogile | Aquacorde | Ruined Portal | 1679936499614135099 | 42340052535445 | 13299712 |
| RO16-1-2 | doogile | Aquacorde | Buried Treasure | -4521571767105223033 | 9169141040074 | 13300018 |
| RO16-1-3 | doogile | Aquacorde | Shipwreck | -7534442143678634363 | 51725690240998 | 13300225 |
| RO16-1-4 | doogile | Aquacorde | Desert Temple | 2288048867353442989 | 244615076066404 | 13300415 |
| RO16-1-5 | doogile | Aquacorde | Village | 207265556819912528 | 95316933538413 | 13300639 |
| RO16-2-1 | v_strid | silverrruns | Buried Treasure | 2625689372677666362 | 241912428251277 | 13301662 |
| RO16-2-2 | v_strid | silverrruns | Desert Temple | 6219686167297541092 | 70876410537330 | 13301896 |
| RO16-2-3 | v_strid | silverrruns | Shipwreck | -6232723066885156565 | 91175017922235 | 13302171 |
| RO16-2-4 | v_strid | silverrruns | Village | 3864114107765164657 | 86134757558044 | 13302518 |
| RO16-3-1 | edcr | lauveer | Desert Temple | 5899955673099426770 | 27958338668791 | 13303619 |
| RO16-3-2 | edcr | lauveer | Shipwreck | 2468235382372099163 | 235337736596154 | 13303909 |
| RO16-3-3 | edcr | lauveer | Village | 545208162905951542 | 238592928875047 | 13304282 |
| RO16-3-4 | edcr | lauveer | Ruined Portal | 1549504780623815428 | 243192422355947 | 13304568 |
| RO16-3-5 | edcr | lauveer | Shipwreck | 8813544817493859226 | 234370381031116 | 13304815 |
| RO16-4-1 | lowk3y_ | woofdoggo_ | Shipwreck | 7215026083676697905 | 225887543589347 | 13305732 |
| RO16-4-2 | lowk3y_ | woofdoggo_ | Buried Treasure | -3611792583857879315 | 66359644784237 | 13306006 |
| RO16-4-3 | lowk3y_ | woofdoggo_ | Desert Temple | -5827492366463797784 | 26043315483785 | 13306291 |
| RO16-4-4 | lowk3y_ | woofdoggo_ | Village | 189419862554060418 | 7335321931203 | 13306585 |
| RO16-5-1 | BlazeMind | bbiddd | Village | 846914099688254655 | 67658481457212 | 13329965 |
| RO16-5-2 | BlazeMind | bbiddd | Ruined Portal | 211732110648809248 | 52100705026705 | 13330204 |
| RO16-5-3 | BlazeMind | bbiddd | Desert Temple | 1468250395378455363 | 36227579527686 | 13330495 |
| RO16-5-4 | BlazeMind | bbiddd | Shipwreck | 3512994394708588908 | 233350056403296 | 13330792 |
| RO16-6-1 | Infume | steez | Desert Temple | 1625875125059084119 | 99584362046436 | 13331666 |
| RO16-6-2 | Infume | steez | Buried Treasure | -7628829678019256118 | 53986620867192 | 13331924 |
| RO16-6-3 | Infume | steez | Ruined Portal | 1261173038105690688 | 236068382736264 | 13332163 |
| RO16-7-1 | Pinne | 7rowl | Buried Treasure | -4481062574134953757 | 55515417348369 | 13333220 |
| RO16-7-2 | Pinne | 7rowl | Village | -6989401529606172821 | 239889065651759 | 13333502 |
| RO16-7-3 | Pinne | 7rowl | Ruined Portal | 180417201285834235 | 236294792312264 | 13333718 |
| RO16-8-1 | Feinberg | nahhann | Village | 1414396871440361991 | 71324300124686 | 13334677 |
| RO16-8-2 | Feinberg | nahhann | Ruined Portal | 1026907535669324911 | 23064516763143 | 13334907 |
| RO16-8-3 | Feinberg | nahhann | Desert Temple | 4089322354568688104 | 59161979199629 | 13335130 |
| RO16-8-4 | Feinberg | nahhann | Buried Treasure | 274886267436806016 | 253987680081977 | 13335355 |
| QF-1-1 | BlazeMind | Pinne | Village | 108096683441216589 | 60610250170999 | 13493574 |
| QF-1-2 | BlazeMind | Pinne | Shipwreck | -6845385625272283797 | 3634016137526 | 13493857 |
| QF-1-3 | BlazeMind | Pinne | Desert Temple | 5354939945064805835 | 25666729515942 | 13494123 |
| QF-1-4 | BlazeMind | Pinne | Buried Treasure | 8399295441590618467 | 264998083425454 | 13494336 |
| QF-2-1 | lowk3y_ | silverrruns | Buried Treasure | -1382517425833255929 | 50733668285791 | 13495280 |
| QF-2-2 | lowk3y_ | silverrruns | Village | -3224386367402416822 | 75371020864198 | 13495481 |
| QF-2-3 | lowk3y_ | silverrruns | Desert Temple | -4872870381829124871 | 231789255725823 | 13495736 |
| QF-2-4 | lowk3y_ | silverrruns | Shipwreck | -7498376214608655229 | 230197690336759 | 13495954 |
| QF-3-1 | Infume | DOOGILE | Desert Temple | 1211563535878332718 | 275522495682766 | 13496975 |
| QF-3-2 | Infume | DOOGILE | Ruined Portal | 477450042130257956 | 225069018138865 | 13497208 |
| QF-3-3 | Infume | DOOGILE | Village | 1450315225811192505 | 98607124130527 | 13497453 |
| SF-1-1 | BlazeMind | lowk3y_ | Ruined Portal | 288313128502456541 | 269566541774294 | 13525852 |
| SF-1-2 | BlazeMind | lowk3y_ | Desert Temple | 410064261403247461 | 43042394533094 | 13526122 |
| SF-1-3 | BlazeMind | lowk3y_ | Buried Treasure | 2143832312393255220 | 92206524691410 | 13526404 |
| SF-1-4 | BlazeMind | lowk3y_ | Shipwreck | 4355252941153179594 | 55769032498593 | 13526669 |
| SF-2-1 | Infume | Feinberg | Buried Treasure | -797116652417404898 | 223377391023892 | 13527460 |
| SF-2-2 | Infume | Feinberg | Ruined Portal | 1270294607500315667 | 248371170784793 | 13527668 |
| SF-2-3 | Infume | Feinberg | Village | 3571527926001901161 | 270783449659668 | 13527899 |
| 3RD-1 | BlazeMind | Feinberg | Ruined Portal | 644060210401442388 | 267885909802124 | 13528697 |
| 3RD-2 | BlazeMind | Feinberg | Village | 306312297464768051 | 264814284968789 | 13529010 |
| 3RD-3 | BlazeMind | Feinberg | Buried Treasure | 1193579534156892194 | 70024359326810 | 13529304 |
| 3RD-4 | BlazeMind | Feinberg | Shipwreck | 391947713299655593 | 58363942410263 | 13529599 |
| GF-1 | lowk3y_ | Infume | Shipwreck | 8885693102324424777 | 63424403036012 | 13530634 |
| GF-2 | lowk3y_ | Infume | Buried Treasure | -3886356321425883779 | 23756406573281 | 13530862 |
| GF-3 | lowk3y_ | Infume | Desert Temple | 6832181259094218468 | 226938205100378 | 13531060 |
| GF-4 | lowk3y_ | Infume | Shipwreck | 3485871065712323679 | 56260011464791 | 13531248 |
