How to comply with recent GLFW rule changes
In the v8 update of the speedrun.com/mc leaderboard rules, custom GLFW builds have to be tracked in legal-dlls.csv. If you’re a Linux user, there’s a good chance you need to follow the steps below to make sure you setup is legal. If you’re a Windows user, you’re probably fine.
If you’re not using a custom build (or “system installation” ) of GLFW, you don’t need to do anything. If you’re using a build of GLFW that was bundled with waywall, you don’t need to do anything. If you’re not sure, keep reading.
If you’re a Linux + waywall user, and when you set up waywall you followed the steps here to compile your own patched GLFW, you’re using a custom, untracked GLFW build, which will no be longer allowed. Luckily, for most waywall users, all you need to do to get in compliance with the rules is use one of the GLFW builds linked below, which are tracked in legal-dlls.csv.
GLFW downloads
if you’re not sure which one to use, probably pick 3.4 (the second one), but it shouldn’t really matter. if you don’t know what “Action Run” or “sha512sum” mean, you don’t need to care about them.
GLFW 3.5.1 with Woofdoggo’s GLFW patch for Waywall
Download: https://femboy.beauty/z8Q3lg
Action Run: https://github.com/r0hkx/mcsr-glfw/actions/runs/38512312952
sha512sum: 9c6f51924ca376ba13936157778de2e7e35be34c69ab904241db32266161f3184974e08daba73eeea91afbab329b23c8e088985845562946e3c015faca9ab036
GLFW 3.4 with Woofdoggo’s GLFW patch for Waywall
Download: https://femboy.beauty/c7IHWg
Action Run: https://github.com/r0hkx/mcsr-glfw/actions/runs/38512301697
sha512sum: 5aa9dc21354770202efd01180c6925fd9bdbe6f1fdddd0b4c23fd7a65de3c287a96d290862094ecdbff3061c7d3d341b3891ea7ced402d4957247882828c6278
disclaimer: these custom builds are being personally provided by me (r0hkx), and aren’t an official product of the src leaderboard mod team, mcsr ranked, or anyone else
Instructions to use a custom GLFW build in Prism
To change it globally (for all instances):
  1. At the top of the Prism window, click “Settings”
  2. Go to the “Minecraft” section
  3. In the “Minecraft” section, go to the “Tweaks” tab
  4. Check the “Use system installation of GLFW” box
  5. Under “Native Libraries”, enter the path of your libglfw.so file into the “GLFW library path”. (You cannot use “~” here, so a correct path would look like /home/yourname/mcsr/libglfw.so)
To change it for a specific instance:
  1. Right click the instance and click “Edit”
  2. Go to the “Settings” section
  3. In the “Settings” section, go to the “Tweaks” tab
  4. Check the “Native Libraries” box
  5. Check the “Use system installation of GLFW” box
  6. Enter the path of your libglfw.so file into the “GLFW library path”. (You cannot use “~” here, so a correct path would look like /home/yourname/mcsr/libglfw.so)
Note: if you didn’t have the “Use system installation of GLFW” box checked in the global settings or your instance settings, you weren’t previously using a custom build of GLFW.
Read A.8.4 (the actual GLFW rules) of rules v8 and the leaderboard announcement for more details. This frontcage post is not an official leaderboard post, it’s just something I personally wrote to help people follow the new rules.
If you want or need another custom build of GLFW that isn’t currently in legal-dlls.csv or available anywhere, and you’re not technical or don’t have time to learn, reply to this post or dm me on discord (@r0hkx) and I can try and help. If you are somewhat technical, it’s possible to get a build legalized yourself. Start by reading A.8.4 of rules v8 so you know exactly what is and isn’t allowed. Though note the rules v8 announcement notice states:
It will not be practical to allow a custom build for everyone so we would appreciate an effort at consolidating who creates and publishes builds.
If you do get a custom build legalized, feel free to post it in this thread (or dm me and I can do it) so others that may need the same build can easily find it.
For an alternate but identical source of the x86_64 library as well as ARM64 builds of v3.4 and v3.5.1 for those looking for them see here :slight_smile:
what the heck is even GLFW and why are the changes even happening
GLFW stands for Graphics Library Framework, and Minecraft uses it for a bunch of things. It’s possible to use a different version of GLFW than what Minecraft normally comes with, and even make and use a custom version of it yourself. Some speedrunners have to use a custom modified version so their game works normally, and some use a custom version to get a (usually very very small) advantage in game. The problem was that the speedrun leaderboard moderators didn’t really know what custom versions of GLFW people were using, and so people could be doing something that wouldn’t normally be allowed, and this rule change helps prevent that.
see the rules v8 announcement notices and rule A.8.4 for more details
